Cabling from my DVD to my Projector
Discussion in 'Cables & Switches' started by (GTV)Chris, Aug 10, 2005.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Hi there,
    I have just bought a Denon 2910 ( I couldn't wait til Blue ray/HD DVD comes out, it may take a while any way) but,
    I have a problem.
    Into my projector (through the walls and ceiling) are Component, composite, s-video and VGA leads - Unfortunately I didn't install HDMI or DVI when I did the rest 2 years ago :(
    I would like to get the best out of the DVD player so I am going to use the component cables for now ( I assume this will produce a cracking image)
    Ideally I need to use DVI or HDMI - But I cant rip the walls down and I have heard that long runs of digital cables are no good - And if I run it round the walls against skirting boards etc I would need approx 15 metres.
    Any one got any good suggestions.
    Perhaps just leaving it at Component will be ok???
    Any help would be great
    Chris
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    (GTV)Chris
    I guess the first step is to try a Digital (over DVI) vs. Analogue (over YUV) test to see if your worrying unnecessarily or not :)
    DVI and HDMI can work over 15m - though not all cables will retain the signal; some will simply not produce a picture and some will cause artefacts.
    Possibly you can find a way to loan a long Digital cable for a 'shoot out'!!!
    Best regards
    Joe
  3. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Many thanks.
    I had a look at the component out last night and it was excellent.
    I don't know if I will try a Digital connection at the moment.. I doubt anyone will lend me a cable and most are expensive and don't want to be in a position were I have to return it - with all the hassle etc.
    Chris
