S
spamboy
I've just picked up an RME DIGI 9636 with AEB8-O and am hoping to get cables made up for it to feed my poweramps directly for a 5.1 setup (hopefully going 7.1 when theatertek supports it).
I was wondering how the cabling on this goes, four of the channels is easy I guess 1/4" TRS jack to dual phonos, but what about the LFE. On my m-audio revolution the centre and sub channels share a socket, is this true of the RME? Will I need to get a cable with an subwoofer cable and a standard audio cable built into the same jack? I'm a bit tempted to use an adaptor on that channel as the sub cable is the most expensive - in case I have to reuse it.
What do you think?
Thanks,
SB
What do you think?
Thanks,
SB
