Cabling a projector - lengths etc???
Discussion in 'Projectors, Screens & Video Processors' started by andy76, Nov 9, 2003.
  1. andy76
    andy76
    Well I keep asking questions and one day I might even buy something!
    Anyway, on to my next question. Looking at how many AV rooms are set up the projector is at the opposite end of the room to the equipment.
    SO....
    How do you all tend to connect the projector?
    Just very long nomal composite or component cables?
    If so where do you obtain cables from? I have looked at the likes of QED cables and they are all short lengths.
    I reckon typically you would need a 10m cable. Does this not cause signal degradation?
    What about positioning?
    Do you ceiling mount them pointing downwards?
    Or set them up on lower tables stands etc?
    Andrew
  2. Kramer
    Kramer
