Cables??
seasider2
Best place on the web to get optical (TOSLINK) cables without going mad? I need 2 x 5m cables for DVD (dvd doesn't have coaxial connection :confused: ) and SKY+.
Maplin have them for £21.99, any good?
Cheers.
Knyght_byte
so as to make sure they are sturdily made, for a 5m length its worth paying around £15-20 a cable...dont bother paying any more as its just the looks you pay for with optical..lol
Profigold make good sturdy and reliable products.....you can buy even cheaper, but sometimes you find things come apart...lol....
joffy1780
It may not be cost effective for one optical cable,but I can highly recommend BlueJeans for all cabling.
I recently ordered some speaker cable,and was informed quickly that the 12-gauge cable I ordered was out of stock.I was then given the 10-gauge for the same price :thumbsup: and the cable arrived in 3 days from Seattle :eek: .
They basically sell the same stuff as the much praised Mark Grant,only cheaper :) .
