Cables too long - change of plan
Discussion in 'Cables & Switches' started by BSDan, Sep 21, 2007.
  1. BSDan
    BSDan
    Nov 3, 2006
    7
    Nothing in life turns out to be that simple. Consequently my TV is a lot closer to the Sky/DVD/amp than expected, thus I am going to have trouble bundling spare lengths of cable particularly speaker and HDMI behind wall units which are on their way. Can I coil these up (if so how tight) to save room. The HDMI are 4 metres. Thanks in anticipation
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,755
    The Borders
    +3,520
    Hello BSDan
    HDMI - don't coil it too tightly; or hang all the weight off of one of the connectors. Use a cable tie or similar to take the weight off of the connectors.
    Loudspeaker cable - if you have lots of spare and don't plan moving the gear then simply shorten the cable.
    If you need to 'coil' it and there is a lot of spare cable lay it in a twin coil 'figure eight' pattern.
    Joe
  3. BSDan
    BSDan
    Nov 3, 2006
    7
    Thanks very much
