Cables too hot?
Discussion in 'Cables & Switches' started by ojock, Feb 23, 2005.
  1. ojock
    ojock
    Jun 1, 2004
    632
    28
    +37
    Hope someone can help a DIY novice
    Just for background info:
    The plasterboard in my house is attached to concrete blocks using the dab&dob method, I will be mounting my plasma above the fireplace mantelpiece using 8*M10*100mm expanding wall bolts to secure. I’ve measured the temperature at where the plasma will seat and there isn’t a problem with heat, I guess with the decorative mantelpiece sticking out quite a bit it seems to help to act as a deflector.
    However, I’ve chased a channel for the cables down the middle of the wall from the plasma and found that when I touched the exposed bricks with the fire on full, it was certainly very hot, not enough to burn me but had to take my hand off within a few seconds.
    So now I’m concerned about the wires getting too hot. I had plan to use white trunking from B&Q, would that be enough to protect them ? If not, is there something that will help ?
    Peter
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Doesn't sound like a great situation to me. You should contact the cable manufacturers and find out what temperature they're rated up to, it's a commonly used specification so they shouldn't mind letting you know.
  3. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello Peter,
    Is there any way you can measure the temperature of the bricks?
    Maybe use an oven type thermometer or whatever has a high enough range.
    Belden PVC insulated cables have a maximum operating temperature rating of 75C, I guess most makes of cable will be similar to give you some idea.
    Hope that helps !
    Mark.
  4. ojock
    ojock
    Jun 1, 2004
    632
    28
    +37
    Thanks to both guys. I'll check the wires & bricks tonight.
    Anyone else have idea on the thermal properties(is that the right word?)/temperature tolerance for the white trunking in general ? I suppose I could purchase one and heat it up & see.
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Again, you can probably find specifications for the white trunking. Try the MK site to give you an idea of what it's likely to be. I would guess it will be similar to the cabling at around 70 or 80degC. :)
