cables to my set up (arcam)
Discussion in 'Cables & Switches' started by Sweden, Jul 5, 2004.
Tags:
  1. Sweden
    Sweden
    Hi!
    i have arcam dv88+ and a90 amp i listen mostly to indie,rock. so ,could someone recommend cables and speakers ?
    Best regards
  2. Starko
    Starko
    I can from my own experience recommend Amphion (Finnish made) loudspeakers with Arcam. Especially the Xenon speaker works like a dream together with the strong current sourcing capabilities of the Arcam designs. The bass response is VERY tight, which should work with your music taste.
    I recommend you buy them from a Finnish dealer over the net, since they seem to be about 25-30% cheaper that way. I have also seen them sold used in Sweden.
    I use my AVR200 with Argon2 speakers for main, one Origo for centre, and old KEF C20's as surround, and I cannot complain. Surprisingly the old KEF's blend nicely into the sound picture when configured as "small".
    Regards,
    Jonas
