Cables (That important?)
Discussion in 'Cables & Switches' started by Bubbauk, Nov 9, 2004.
  1. Bubbauk
    Bubbauk
    Sep 27, 2004
    178
    Belfast
    +4
    Im ordering the folowing equipment for my xmas present and i cant afford any good cables for it YET but will have them abotu 2 months after xmas when i get my tv also, so here is what im getting
    Marantz SR4400B A/V Receiver
    Marantz DV4300B DVD Player
    Tannoy FX5.1 Speakers
    And the folowing tv at the same time i get the cables
    Panasonic TX28PM1C
    Now here is the question, will the cables that this equipment comes with be ok for listening to music untill i get the more expensive scart, phono, digital, subwoofer cables? Or will i notice this system performing crap with usuing the standard cables they come with?
    Any help or opinions apreciated. Thanks.
  2. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    The bundled cables(especially Scart's etc)with most gear tend to be of the lowest possible quality,but will obviously work.
    My own advice is not to spend a huge amount on cables unless you have a very expensive system,but to buy some reasonable quality cables in each sector(speakers,interconnects etc),but I certainly wouldn't put more than £200 into it as a total,at this price level.
    All the usual names are worth considering(VdH,Chord,Ixos,QED etc).
  3. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,456
    64
    Norfolk
    +217
    Cheap scart cables can be very nasty. I've seen wires used in place of coax, and braids broken away at terminations.
    Decent quality budget cables exist, however- check out Maplins.
  4. Bubbauk
    Bubbauk
    Sep 27, 2004
    178
    Belfast
    +4
    Thanks for the replies, i will definatly be spending about £100 on the cables then some more on speaker cables when i get the tv but for the first 2 months of having the system it will just be a cd player and will be used with the cables it came with, im just wondering would i be able to still listen to good quality with the stuff it comes with, considering ive never listening to music through anything in my home or my friends homes that have used quality cables i think it sounds ok.
  5. andrew markwort
    andrew markwort
    Jun 20, 2004
    1,156
    63
    +159
    I found the biggest benefit was in upgrading the DVD-TV link. After that, it was diminishing returns.
