Cables for Tosh 36ZP38 and Xbox prog scan?
Discussion in 'General TV Discussions Forum' started by Fergal, May 21, 2004.
  1. Fergal
    Fergal
    May 21, 2004
    12
    I'm thinking about buying the Tosh 36ZP38 to use with my xbox for games/movie playback. I would like to use the xbox prog scan mode if possible. I've seen the x2vga cable (www.x2vga.com) which seems to be what I need, and some circuit diagrams for diy cables. The x2vga cable is a bit pricey, do I reallly need it? What cables are other forum members using for this?
    Also, does anyone know if lightgun games will work with this TV?
    Fergal
  2. simongwynne
    simongwynne
    Dec 30, 2003
    323
    28
    +57
    I got the official Hi Def pack from the US, which came to a little over a 12 quid with the exchange rate as it was. Light gun games don't work well at all I'm afraid, I'm guessing due to the wide screen, but I don't really know. I haven't tried playing one with the TV in 4:3 mode as it would mean turning the prog scan off.
