Cables for Sky Digital > TiVo > plasma?
Discussion in 'Cables & Switches' started by Lee James, Dec 20, 2004.
  1. Lee James
    Lee James
    Dec 11, 2004
    315
    I'm shortly getting Sky Digital and I'd like to buy a really good SCART to SCART to hook it up to my plasma (I believe SCART is the best output Sky Digital has). But on the other hand I'll probably be getting a TiVo or some other HD recorder in the near future, and leading it through that. So I'm wondering what leads I'll need when I get that. I have no idea what input/output these HD recorders have.
    Quality is really important since the connection will be going through two cables to get to my screen. Will I be wasting my time buying a SCART to SCART now, or will that fit into the sytem nicely when I add the TiVo?
    Anyone have any advice?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    TiVo only has scart input & output, so a good quality scart lead will be what is required.
    What budget do you have for the 2 scarts?
    Mark.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    Just checked and This is the scart I use between my Freeview box and TiVo.
    Mark.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Why not get Sky Plus now which is Sky Digital with a built in HD recorder. It will save you another box with yet more connections.
