Cables for rear speakers
Discussion in 'Cables & Switches' started by Nik1967, Nov 4, 2004.
  1. Nik1967
    Nik1967
    Jun 22, 2004
    52
    Hi guys,
    My fronts and center speakers (B&W601 & LCR60) are connected to my receiver with 4mm2 thickness cables.The cables for the rear speakers need to travel quite a distance (approx 8- 10 m), so I wanted to know if the same thickness is required or would thinner cables suffice. Don't want to compromise on the quality of sound.
    cheers
    Nik
    P.S Mylo - if you read this - thanks a ton for your tip on fitting the banana plugs to my receiver. Cool :)
  2. Knightshade
    Knightshade
    Aug 6, 2004
    1,996
    +43
    My choice would have to be Cat5 cable over that distance. Certainly wouldn't be any compromise on quality.
  3. Nik1967
    Nik1967
    Jun 22, 2004
    52
    Are those the same cables used to connect computer hardware??!! or are they some special make of speaker cables??!!
  4. WarLock
    WarLock
    you mean UTP cat 5 ?! but thats network cable ....
  5. Nik1967
    Nik1967
    Jun 22, 2004
    52
    thats the only one i heard of :blush: where do i get the cables you mention?
  6. Knightshade
    Knightshade
    Aug 6, 2004
    1,996
    +43
    Exactly the same stuff. Bottom line is it's good enough to carry data with no loss over 100m so it's good enough for audio. You need to do a bit more to it than just run it around the room. Basically you use 3 cat5 cables and braid them together. Tough work on your fingers but worth it. PM if you want more details.
