cables for everything!?
Discussion in 'Desktop & Laptop Computers Forum' started by rsvrmille, Jul 21, 2003.
  1. rsvrmille
    rsvrmille
    now, the pc is up and almost running (see sapphire graphics card thread) and i have a couple of quesitons left
    1. I take it I need a digital audio cable from the dvd to the soundcard for best sound, unfortunately the Lite-on DVD player i bought only came with the analogue one. Where can I get a decent digital one from.
    2. I also need a good quality cable for the digital out from the audigy 2 card I bought. Any suggestions?
    3. While I am at it, what is the best DVI-DVI cable to buy and where can i get it from?
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    You shouldn't need any additional connection to the souncard the data will pass over the PCI bus in some magical fashion. Go into the drive properties and enable digital output for the dvd drive.
    Depends what you are outputting and inputting to your amp? Spdif/coax using a decent phono lead will work fine . For optical buy a decent quality toslink cable,
    Don't use dvi sorry.
  3. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    Don't worry about the internal digital audio connection between the drive and the sound card, it's an old function that's never used. All the data you need is transferred via the IDE and PCI interfaces.
    if the audigy has coaxial output then someting like this would be fine. They also do optical leads if that's what you need.
    Can't help with no. 3 I'm afraid.
    Owain
  4. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
  5. rsvrmille
    rsvrmille
    if i have onboard sound with spdif optical out (which i do) should i use this or the sound out on the audigy 2? Will there be any difference in sound quality? The audigy2 has a 3.5m digital out jack.
  6. philipb
    philipb
    Mar 6, 2002
    2,051
    63
    Swindon
    +153
  7. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I guess you'll just have to try and see without knowing anything about your onboard sound. I suspect teh audigy might be better btu then again you might not be able to tell the difference : certainly for DD,DTS playback ....CD might be another story: look for 48khz upsampling for furtehr info on this.
  8. Desmo
    Desmo
    Jan 4, 2001
    14,190
    Braintree, Essex.
    +5,866
    Hello fellow biker ;)
    I'd agree with Mr.D and say the Audigy would probably be better than your onboard sound.
  9. rsvrmille
    rsvrmille
    Right, went to maplin last night, got a 3.5m to phono converter
    http://www.maplin.co.uk/Products/Mo...ID=030812092857889&moduleno=34197&modulelist=
    Plugged this into the digital out from the audigy, connected using a coaxil(sp?) to the coax digital in on the amp (sony strb 930).
    The sound comes through as 96khz PCM which is good but it only comes through in stereo and the amp will not pickup the 5.1 encoding for some reason. I have the soundcard set to output digital sound only and it is set to 5.1 speakers. What gives?
    this hcpc lark is sooo frustrating:mad:
  10. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    Is it the software DVD player itself needs setting?
    I use Power DVD and have to set it on a menu to use SPDIF output to pass the DD signal direct from the player to the Optical/Co-Ax output. (Built in on motherboard)
  11. rsvrmille
    rsvrmille
    i think you may be right. will check at home tonight. pain in the arse only having internet access at work :(
    thx for the help. I've got powerDVD xp 4
