Cables for budget home cinema
Discussion in 'Cables & Switches' started by ismangil, Dec 9, 2004.
  1. ismangil
    ismangil
    Nov 30, 2004
    65
    Sheffield
    After trawling around, I've now sourced my cables from beststuff.co.uk (not affiliated, just a satisfied customer). Look for the Hama range. I've got the Component-VGA at £25, S-Video at £19.50 (both 10m), and the 6 phono (for 5.1 DVD -> AV Receiver) at £12.
    The component-VGA in particular works well with the Infocus X1 (you can tell this is the absolute minimum budget pj home cinema ;) ).
