Cables for a "Under 500 pounds" Home Cinema Speaker Package
Discussion in 'Home Cinema Speakers' started by coolhand101, Dec 4, 2003.
  1. coolhand101
    coolhand101
    Well searching hard for a decent cable i have decided on these two-
    1.Mordaunt Short Silver Maestro
    2.IXOS 607 Self Adhesive Speaker Cable
    Could anyone recommend which one?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    I use Ixos 607 for my rear speakers which I am very happy with. It has the advantage of being flat so slips under carpets very easily
  3. Rainbow6
    Rainbow6
    Sep 23, 2003
    247
    16
    Belfast
    Ian,
    Out of curiosity, what are you using for your fronts?
  4. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    Silver Anniversary - same as everyone else seems to use
  5. Rainbow6
    Rainbow6
    Sep 23, 2003
    247
    16
    Belfast
    They work fine together, then? - I mean it doesn't matter if you mix and match brands (IXOS £ QED)?
    Thanks in advance.
    J.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,310
    +1,217
    dont mix and match on same speaker but between rears and fronts no worrys most people use a lesser cable for rears as lengths are longer an sound less important as less range is direct to rears for 5.1 Movies SACD and DVD-a is different
