M mark88 Prominent Member Joined Oct 25, 2004 Messages 878 Reaction score 23 Points 279 Oct 13, 2007 #1 What are you guys using to finish off holes where cables you have buried in walls have to exit? ie, making the hole look neat and tidy.
Miniholic Prominent Member Joined Apr 26, 2001 Messages 3,071 Reaction score 402 Points 532 Location The Shire Oct 13, 2007 #2 I'm using blanking plates to make speaker connectors that match the other sockets/switches in the room. Have a look HERE. The blanks are from screwfix, and the connectors from CPC.
albriscoe Prominent Member Joined May 29, 2007 Messages 5,705 Reaction score 843 Points 946 Oct 13, 2007 #3 I used the same as Ian but if you just mean cables coming out from walls what about this, simple, cheap but very neat and tidy to this this cost £1.25 AND LOOKS QUITE NEAT DON`T YOU THINK hope this helps Allan
M mark88 Prominent Member Joined Oct 25, 2004 Messages 878 Reaction score 23 Points 279 Oct 13, 2007 #4 albriscoe said: I used the same as Ian but if you just mean cables coming out from walls what about this, simple, cheap but very neat and tidy to this this cost £1.25 AND LOOKS QUITE NEAT DON`T YOU THINK hope this helps Allan Click to expand... yea, where do you purchase those?
albriscoe Prominent Member Joined May 29, 2007 Messages 5,705 Reaction score 843 Points 946 Oct 13, 2007 #5 Hi Mark any electrical wholesaler, its just a plaster board box and a blank cut with an hole in it Like I said mate nice and simple Allan
