Cables, Cables etc...
Discussion in 'Cables & Switches' started by flukeskywalker, Apr 5, 2005.
  1. flukeskywalker
    flukeskywalker
    Mar 22, 2005
    110
    I am on the verge of shelling out for a 32" LCD TV.
    I will mostly be using it for watching DVD's and playing PS2 and I want everything to look as good as poss. :eek:
    If I buy a pricey RGB cable, does that carry sound aswell or do I need a seperate cable for that? :confused:
    If it does, then whats the best RGB cable for around £20-£30 quid?
    I've seen some for around £40-£50 which is too much.
    Any help would be appreciated.
  2. Daneel
    Daneel
    Dec 5, 2002
    2,822
    68
    London
    +26
    Scart carries sound as well as video. You may well have a component option on an LCD display which is a better option that Scart if you have suitable outputs on your DVD player.
  3. flukeskywalker
    flukeskywalker
    Mar 22, 2005
    110
    Thanks for responding, LCD unfortunately doesn't have a component option so I'm going for a RGB scart instead.
    Thanks again :smashin:
