cables cables cables
Discussion in 'Projectors, Screens & Video Processors' started by dyl33, Jul 2, 2005.
  1. dyl33
    dyl33
    Feb 14, 2005
    24
    Bought the epson emp tw10h last week and i'm struggling with the connections for the different devices that i have
    Dvd:- (none progressive)s-video to s video to the pj or scart to 4 rca to the pj
    sky:- scart to 4 rca(sync) to the pj
    ps2:- composite to composite in but here's the problem
    if i've got to use the 4 rca option for sky or dvd then the composite is being used for the sync
    can i use scart to 15 pin for either devices and what cable do you experts recommend
    This has been doing my head in all week
    Thanks in advance
  2. cyberheater
    cyberheater
    Apr 3, 2003
    3,200
    Scotland
    +178
    Can you not get get a scart switchbox?
  3. dyl33
    dyl33
    Feb 14, 2005
    24
    scart switch box
    with what out-put?
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,227
    The Borders
    +2,937
    dyl33
    I'll assume your DVD player is SCART RGB enabled!
    If yes then simply 'Daisy Chain' it (SCART to SCART) to the SCART Input on the SKY+ Box and when you want to view the DVD player put SKY+ into Standby (doesn't affect any programmed recordings).
    Does the Projector user manual mention support for RGB+Composite sync on the HD15(VGA) socket?
    If not then its easy enough to supply a SCART to HD15(VGA) cable with an additional 'Tail' for the Composite Sync on an RCA plug.
    For your PS2 I'd splash out on an Upgrade kit and enable YUV Component out and connect that to the YUV Inputs on the Projector.
    Best regards
    Joe
