Cables cables cables.....
Discussion in 'Cables & Switches' started by Doobrey, Nov 28, 2017.
  1. Doobrey
    Doobrey
    Nov 28, 2017
    2
    Uk
    ok guys,
    Need some honest advice. Bought a lovely 4k projector, uhd550x.
    Now my dilema. 15m cable run.
    I need options pls, i can of course purchase a 15m fibre hdmi cable, but is there such thing as a copper cable called ultra hdmi that can go 4k over 15m?
    I tried cheap cat6 hdmi extenders, but didnt work for me, but happy to have these as as a suggestion.
    Whats the gig guys? How do i get this to work?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,861
    The Borders
    +3,556
    Plenty Standard Speed Copper cables called all sorts of things at 15m - still highly unlikely they will deliver a 4K UHD signal to your Projector.
    Often the longer lengths (8m+) of cables Certified as High Speed are advertised along with the shorter lengths with a foot note indicating the longer lengths do not meet the High Speed Certification.
    The only Certified (by HDMI.org) categories are Standard, High Speed and Premium High Speed - no mention of ‘Ultra’ anywhere.
    Whatever you go with have a plan which allows easy replacement of a damaged, failed or obsolete cable.
    Joe
  3. Doobrey
    Doobrey
    Nov 28, 2017
    2
    Uk
    Thanks for coming back to quickly Joe!
    So could you recommend me a solution please? Fibre appears to me to be the best option available today, 15m is around £199 I believe.
    What do you think about CAT6 in the walls with some sort of HDMI extenders? Any good reviews on those? I am open to options.
    Cheers,
    Chad.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,861
    The Borders
    +3,556
    HDMI over CAT6 - the most stable solutions are based around the HDBaseT (HDBT) technology. The latest (Gen 2.0) HDBT chip set caters for 4K UHD using 'visually lossless' compression by Lattice Semiconductors technology - certified units are very expensive (many in excess of £1K).
    Ruipro Hybrid Fibre are what we supply and install where an HDMI cable is an option and so far we have had great results.
    Joe
  5. Abacus
    Abacus
    Jan 19, 2015
    741
    67
    Torbay
    +479
    Another option which may be cheaper depending on how you cable is run, is to buy 2 x 7.5m ultra rated cables and an Ultra HDMI extender/amplifier (You will need to have mains power available to run the extender/amplifier) to join the 2 cables together.
    Bill
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,861
    The Borders
    +3,556
    '2 x 7.5m ultra rated cables' - that would be 2 x High Speed or Premium High Speed cables :)
    Joe
