Hi all,
Not very sure of what i'm after in terms of cabling. I have a :
Pioneer 565A
Pioneer VSX AX3 Amp
Sky+
the amp (AX3) is on order, so need to look at cables now. I was told something about having to use 3 cables to be able to use the SACD and DVD-A sounds, rather than a D/co-axial, can anyone advise on this? What cables should i buy to connect my DVD to the amp and use for music and Cinema. Don't want to spend a fortune, so try not to suggest mega expensive cables if you could!!
Martin
Pioneer 565A
Pioneer VSX AX3 Amp
Sky+
Martin
