Cable Wiring
mr gadget
Greeting,
I have bought Kef 2005.2 eggs to go with the Pioneer amp AX4ASI-S and i would like to know what cabling for the speaker to go for.
There is such a in price - 50p to £10.00 lm, but i do not want to pay more than £5.00 lm
Scott_Mac
Folks report good results with the stuff from Mark Grant, though i've not tried it myself it is pretty cheap..
https://markgrantcables.co.uk/index...s_id=70&shop=abe18b14cddb0b0259e9e1762172cb8b
I use the QED Silver Anniversary stuff for my rears and that is also very good, slightly over your budget by 50p though:
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/2514
However for sensible money (and buying new) i'd get Chord Carnival:
http://www.hificables.co.uk/Product...D/2392/v/fa79dadb-2303-42ba-80b0-411ec08533a3
If you're prepared to buy used you can get Chord Rumour and even Odyssey for bargain prices on eBay.. for instance a 3m pair (i.e. total 6m) including terminations usually goes for approx £40 and that's well worth it!
Cable Monkey
I have been using Van Damme Blue studio grade 2x 2.5mm cable for a while now. I got mine from Maplin though there was a rumour they were going to discontinue. I believe it is the prefered choice of studios and the BBC which suggests it is both neutral sounding and robust in construction. I have certainly found it suits both my AV and stereo setup and would happily recommend it.
mr gadget
Thanks for your help:thumbsup:
H
hammers80
They are KEF eggs,you don't need the Chord company oddessy for thoes:suicide: :D ,try the van damme,or The chord Co leyline about 1.50 metre.
Coolit
I have the same 2.5mm Van Damme cable although I've not tested it yet having just finished terminating it all, I can comment on its quality which is very high, its also nice and flexible making it ideal for going round skirting.
If you look in the powerbuy section of the forum you can get it at a discount price from Joe.
Scott_Mac
No you don't, but for £40 terminated it's a bargain and it's not as if the speakers are going to complain about having decent cable attached now really is it...
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
