Cable upgrade for PC monitor?
Discussion in 'Cables & Switches' started by Pezerinno, Jan 17, 2005.
  1. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,460
    71
    Southsea
    +69
    I need a longer DVI-D - DVI-D (male-male) cable for my pc monitor so was wondering whether I should upgrade to a better quality one. Will it have a performance gain similar to other a/v stuff?
    Also is there anywhere that sells 3 metre DVI-D cables? they all seem to be 1m, 2m, 5m, 10m etc.
    Thanks.
