cable tv connection
Discussion in 'Cables & Switches' started by mattytinter, Jul 28, 2004.
  1. mattytinter
    mattytinter
    Jul 28, 2004
    27
    3
    i wonder if any one could please advise me, ive got a pw6 plasma with component board, ive got a pioneer progressive scan dvd player, i can connect my dvd via component no problem, its my digital cable box from telewest, its only got a scart output, and wondering the best way to connect to my plasma... a scart to component lead maybee?? would it work if the scart output on the cable box isnt rgb, cause i dont think it is rgb scart output, im using a av amp to route my sound and pictures, all the connections on my av amp are component .
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    You should check first what output your cable box supports. Scart can carry Composite, S-Video and RGB, but not Component/YUV (with the exception of some Loewe TVs).
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    All digital Sky boxes output RGB through the scart and NTL digital cable does as well so I wouldn't imagine Telewest to be any different
  4. AMc
    AMc
    Nov 20, 2000
    7,024
    Near Norwich
    +3,659
    Digital cable from TeleWest is RGB - you have to enable it in the menus on the STB.
  5. mattytinter
    mattytinter
    Jul 28, 2004
    27
    3
    thanks for the info. so based on these facts i could use a scart to component lead..
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    no you need a converter try JS technology top quality or RGB>VGA converter save you buying another input board.
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,053
    The Borders
    +3,166
    mattytinter
    What you require is as follows:
    Set-up:
    Your Telewest Digibox set to output RGB via its SCART socket.
    Video connectivity:
    1 x SCART cable (I'll come back to which sort in a minute).
    1 x RGB2YUV Converter ( I always supply/recommend JS Technology converters)
    1 x 3RCA to 3RCA 'Component' video cable.
    You connect the Digibox to the RGB Converter using the SCART cable and the RGB Converter to your AV Receiver with the 3RCA Component Video cable.
    Audio connectivity:
    If your Digibox has a set of Stereo Audio outputs or a Digital Audio output use these to connect to your AV Receiver.
    If Audio is only available via the Digibox SCART socket ensure you get a Fully Wired SCART cable between the Digibox and the RGB Converter - the JS Technology RGB Converter has a set of RCA 'break out' stereo audio outputs that you can then connect to your AV Receiver using a Stereo Audio cable.
    SCART cables:
    If you do have Stereo or Digital audio connectors on your Digibox you then have the option of a higher quality (cost) RGB Only SCART cable between the Digibox and the RGB Converter and no requirement for Audio via the RGB Converter.
    Dead simple :)
    Best regards
    Joe
  8. zedzed
    zedzed
    Jul 12, 2004
    821
    Linlithgow (nr. Edinburgh)
    +13
    From what I gather from other posts (I'm a relative newbie at this!) what Joe recommends will give you the best quality signal, but during the convertion process you'll loose the "auto aspect switching" that Scart provides.
    Might not be an issue (it is for me as it means the Mrs. will get hacked off having to mess about with the settings!) - but I thought I'd mention it :)
    ZedZed
  9. mattytinter
    mattytinter
    Jul 28, 2004
    27
    3
    Many thanks Joe, i understand it fully now, your info is greatly apreaciated , Matty
  10. mattytinter
    mattytinter
    Jul 28, 2004
    27
    3
    i was just thinking over the previous posts, Hornydragon has a good point, if my dvd player is running components, and i run another set of components for my cable box, which means another input board.. but if i get an rgb-vga converter, i dont need another board, so would the quality be as good as a rgb to component .or are they nearly the same.
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    very similar, one board and a converter or just a converter the costs the same????
  12. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,053
    The Borders
    +3,166
    ZedZed
    Good point - though I have to say most folk seem to get used to manually switching aspect ratios (when they can be bothered) or put up with the odd 'soap' in a distorted format.
    It seems to be something many folk find less of an issue with on larger format screens.
    Best regards
    Joe
