cable tidy
Discussion in 'Home Cinema Speakers' started by barrykil, May 7, 2002.
  1. barrykil
    barrykil
    Jan 17, 2002
    2,380
    48
    +26
    hi my tv is about 3mts from the amp, where would be the best place to get some sort of flexable tubing to go over the linking cable and various speaker cables to tidy them up a bit, thanks for your help.
  2. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Ikea do some black or white tubes that work quite well if you use extra cable ties with them. They are REALLY cheap!
    I have:-
    1 Scart
    5 Silver Anniv. Speaker Wire
    1 Aerial Lead
    1 S-Video lead
    I need to take it all apart to add:-
    1 Ixos 109 Sub Cable
    1 Pair Phonos for Digibox
    All in the same tube, but it's already a bit packed in there!
    Alternatively Maplins do various dimesions of cable wrap.
    Mark.
    Mark.
  3. alextgreen
    alextgreen
    Apr 17, 2001
    550
    London
    +5
    I have lots of red/blue/yellow/translucent cabling, so I just tie the main runs together with multi coloured cable ties. They're never going to be 100% tidy (too much stuff plugged in) so I don't worry about it and just keep the lights turned off.
  4. barrykil
    barrykil
    Jan 17, 2002
    2,380
    48
    +26
    good idea alextgreen but i think i`ll go with marks solution, cheers
  5. wflem007
    wflem007
    Barry
    I bought white conduit from B&Q - it comes in various thickness to accomadate suit single or multiple cables.
    There is a version that has that sticky stuff on the back of it, so fixing it just above your skirting board is easy and you would never notice it.
    It is also paintable so you can match it in with your deco.
  6. barrykil
    barrykil
    Jan 17, 2002
    2,380
    48
    +26
    has to be flexable tubing to go around 2 corners, thanx wflem007
  7. wflem007
    wflem007
    Barry
    It comes in straight lengths, but you can buy matching mitred corner joints, or indeed if you have a mitre, cut the ends yourself.
