Cable tidies!
Discussion in 'Cables & Switches' started by longleyc, Sep 14, 2005.
  1. longleyc
    longleyc
    Apart from the obvious benefits of the cable tidies, is there any issues with bunching a whole load of AV cabling in one tube?
    My guess theres a lot of electro magnetic interference in one place. Though my Component/Scart and Digital cables are Screened, the speakers arent.
    Any comments?
  2. Troon
    Troon
    Apr 28, 2005
    151
    In theory, yes, it's a bad idea. In practice, I've not noticed a problem, even running RGB SCART, mains, and five speaker cables in a bundle for over 3m. The SCART cable wasn't anything special, either.
    Note that the lack of screening on the speaker cables is bad news for *other* cables: due to the low line impedance, the speakers won't pick up any interference of significance.
  3. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    Also, if you use cable ties with coax cables, do not squeeze the cable because this drastically alters the cable characteristics, and could alter your system performance.
    Also, adhere to the minimum curve radius for the cables your installing as bending too tight can also give the same results as above.
    Gareth.
