Cable supplier for Scart to 5 BNC
samraj
I need to connect my Panny DMRE100 to NEC Plasma, CPC doesn't have the BNC cable. I need a Scart to 5 BNCs(plasma) - suggest supplier
cybersoga
Regular RGB Scart output doesn't have H & V sync, it uses the sync from the composite video signal, which means you can't use a strait cable. How do these Keene cables work?
The Best Movies and TV Shows Coming to Netflix in November 2020: Tom's Thumbs.
