Cable Splitter
Discussion in 'Subwoofers' started by arn, Jan 24, 2005.
  1. arn
    arn
    Dec 26, 2003
    270
    Bury
    :hiya:
    My subwoofer comes with 2 inputs but my receiver only has 1 output, Is it worth getting a cable splitter so the 1 cable becomes 2? Any benefit at all in this? Also is it worth upgrading the cable on the sub?
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    what sub is it?
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I wouldn't bother with a cable splitter unless you're having trouble with an auto-on circuit not initialising quickly enough.
    Probably not worth bothering with a different cable unless the one you're using at the moment looks to be poorly constructed.
  4. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    I've heard that they can work, but heard that it would work with my sub - I still went out and bought one to see what it was like, but for my sub - it just sounded terrible...thats not to say it won't work for your setup...
    this is the one I bought - http://www.tvcables.co.uk/cgi-bin/tvcables/XFA08-Y1F.html
  5. arn
    arn
    Dec 26, 2003
    270
    Bury
    That's the cable i was looking at as well.
    Mylo it's the av50 from unbeatable :) the nsp100 set up.
    Think i will leave it for now and concentrate on getting good speaker cable.
    Thanks anyways :thumbsup:
  6. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    edit - meant to say that I'd heard it wouldn't work with my sub...! ;)
  7. Andrew K
    Andrew K
    Oct 14, 2004
    3,380
    +605
    You could get a custom made cable. I have a Chord cable with a 1 RCA to 2 RCA configuration. This removes the need for a splitter. It is not costly either, you are just paying for another run of cable.
  8. Nimby
    Nimby
    Jan 27, 2004
    9,204
    The Danish Bacon Factory
    +670
    The theory is that using a splitter cable to feed both low level subwoofer inputs achieves about a 3dB gain in output. So the sub is louder. Wow! :cool:
    But now you have to turn down the gain on the sub to compensate. Or the sub will sound far too loud compared with your speakers. :blush:
    So what have you really gained? Nothing. You've lost the cost of the cable. Which would have bought you a DVD or two. :clown:
    Nimby
  9. arn
    arn
    Dec 26, 2003
    270
    Bury
    ahh now i get it :thumbsup: . will buy another dvd then seeing as my sub is never turned right up anyway.
