Cable splitter question
LeeMc
Hi All,
I want to use my TV as monitor for a new computer in the lounge. I already have the virgin TV connection in there.
If a buy a cable splitter and wired router will I be able to use this connection to connect to the internet through the tv?
I have a broadband connection at other side of house so I suppose I could go wireless but not sure I trust wireless- am I wrong?
jsansom007
Yes you can split the connection but you would still need to use the modem provided by cable to connect to the net on your new computer which you have moved by your tv. The only way to get both computers working on the net would be to use the wired router like you have said and run a ethernet cable to the other computer or go wiresless which is safe just make sure you run the wirless connection in secure mode
Hope that helps
Regards
J
LeeMc
Thanks J
Can I buy another modem? is this the same as a router?
I have seen Virgin wired routers for sale on Ebay.
again
Tkrockeruk
No one has the right to sell virgin equipment other then virgin themselves. People should not be selling their equipment online.
And no, the virgin Modem via ebay will not work if you plugged it in at your end, they need MAC codes assigning to them, which requires a technician.
jsansom007
Thanks J
again
You would have to pay monthly for a second modem from virgin and all they are selling on ebay is virgin branded wired/wireless routers not modems your best option is wireless for the other computer or run a second ethernet cable to it m8
Regards
J
