cable runs.
Discussion in 'Cables & Switches' started by krusty, Aug 1, 2004.
  1. krusty
    krusty
    im using a 5.1 system , and am about to bring 2 effects speakers into use[ my amp is yamaha a2] will i have to use the same length of cable as all the other cables?
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,499
    2
    71
    High Wycombe, Bucks, UK
    +59
    Use the length you need you make the run and a little extra for flexability if needed later.
