Cable router thingymebob?
Discussion in 'Networking & NAS' started by (GTV)Chris, Jun 4, 2003.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    I am having cable fitted and wondered if there is a device that i could use to sit between my pc and my wifes Mac so we can both gain access to the internet??
    I have heard of a router, is this what I need to ask for?
    Thanks V much
    Chris
  2. RedBull
    RedBull
    Jan 30, 2003
    157
    Darlington, UK
    +27
    Yeah, you're after a router.
    Have a read through practicallynetworked.com and semi-basic instructions on how to do it, plus there's a few FAQ's at this site, along with some general router info.
  3. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    cheers dude.
  4. eddiewww
    eddiewww
    Nov 14, 2002
    507
    46
    Blackheath, SE London
    +145
  5. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    Unless they have changed their policy, If you are using Telewest you should get a router that allows you to set the MAC address manually, as the connection is set up to a specific network card in the pc on installation. If you clone this address to the router, Telewest think you are still connected to the same PC, not a router.
    This does not apply to NTL
    More details on broadband on this excellent site:
    http://www.nthellworld.com/
    (Also relevant to Telewest)
  6. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Thanks for all the info fellas.
    Just one thing though - If i leave my pc on the internet all night downloading, as I do at present with ADSL, Will NTL cut me off after a time limit?
    Do they also cap your download sizes?
    Ta
    C
  7. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    No.
    No.
    I have used Kazaa/eMule for files of 1/2 GB over several days with no problems
    My router and at least 2 PC,s are on 24/7 and have been for the last 3 years
