Cable recommendations
Discussion in 'Projectors, Screens & Video Processors' started by VintageMark, May 22, 2001.
  1. VintageMark
    VintageMark
    Apr 27, 2001
    160
    16
    Bristol
    Hi..
    Can anyone help me out with a cable Im after...
    Im trying to connect an Iscan Pro to a Sim2 HT200...
    Dont actually have either yet... I know both connectors are 15pin D type VGA connectors... but I dont know which is Male and which is Female etc....
    Can anyone tell me? Additionally... can anyone point me at somewhere online that will sell me a good quality cable for that purpose?
    Many thanks,
    Mark.
  2. chris thomas
    chris thomas
  3. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    Mark,
    For iScan to HT200 you need a male to male 15pin D cable.
    To tell the difference between 15pin D male and female just look at the plug end - if it has three rows of little pins then it's male, if there are holes then it is female.
    Regards
  4. VintageMark
    VintageMark
    Apr 27, 2001
    160
    16
    Bristol
    Once again many thanks Chris... incredibly helpful as always!
    I'll take the male female tip as a hint to cut back though! Many thanks anyway...
    Mark.
  5. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
