Cable recommendations for Kef Eggs
Discussion in 'Home Cinema Speakers' started by Ally, Feb 9, 2003.
  1. Ally
    Ally
    Hi everyone
    Any cable recommendations for my soon to arrive Kef eggs. They will be fed from a Yamaha RVX-630 reciever and I will probably need about 20-25 metres in total. Also can anyone tellme how these terminate at the speaker. Will standard bananas be ok?
    Ally
  2. vee_cee
    vee_cee
    Ally
    I use QED original (front LCR) and QED micro (Rear LR), but personally as long as it's OFC (Oxygen Free Copper) cable it depends on your budget as to which you should get.
    Original is £2.50 a metre and Micro £1.50 a metre.
    Termination wise either banana's or bare wire can be used, I prefer the later.
    VC
  3. Silent Fly
    Silent Fly
    Ally,
    I suggest you the excellent Maplin "HD Loudspeaker Cable" (code: XR60Q) 0.49/mt.
    I use it with my Marantz 5300 and 6 eggs + sub.
    The eggs accept the cable with or without bananas.
  4. Ravi 123
    Ravi 123
    Qed original can be had from the Hifi Store for £2m a metre only a saving of 50p a metre but it all counts........:D
  5. Bogside
    Bogside
    Sep 20, 2002
    3,141
    Stockport (ex Derry)
    +418
    My two-penneth: I got the QED original for my KEF's (front and rears)
