Cable Recommendation Needed
Discussion in 'Cables & Switches' started by cjob68, Dec 15, 2004.
  1. cjob68
    cjob68
    I just recently replaced my 32" with a 46" Hitachi Rear CRT. Thus my stand that holds all my gear will be moving with the old tv. I will need to move all my stuff ( dvd player , pvr unit , satellite receiver , receiver etc ..) into some built in shelves that are beside the tv. However , the shelves aren't pre-wired so I need some way of doing the following:
    1. Running my video to the new tv
    2. Running a power bar into the new shelves so I can plug all my stuff in
    3. Hiding all the wires connecting dvd to receiver etc ... as much as possible. ( this ones easy because I can just buy some of the wire duct they make to hide them ) .
    The shelves are on the left side of the tv so I suppose I can either do the following:
    1. Run the wires down a corner to the rug and then underneath the run or the wall. I could then use the wire duct to hide the wires. However , to do this I would need to run an extension cord into the shelves and then hook a powerbar into this. ( I don't know how good that is )
    OR
    2. Make a hole in the side of the shelves ( beside the tv ) and get some type of outlet cover and run the needed wires through that.
    Has any one done a similar thing and what did you do ?
    Jason
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    jason some pics could really help as i cant quite visulise what you are trying to do mate...
  3. cjob68
    cjob68
    Here is some pics of the shelves . Any ideas would be great.
