Quantcast
cable quickie
Slime101
Not getting any help anywhere else!!! so i shall try here...
Just about to order the following but unsure of what type and brand of cables i need!
Sony DVD - DVPNS705 (multi-region) £198.95
Sony AV Reciever - STRDB780 £224.99
So what cables do i need for CD audio playback - will the same one work for SACD??
What do i need for the DVD audio 5.1??
Cheers Guys :)
Jase
For standard cd playback you can use either a pair of analogue phono cables (which means you use the digital to analogue converters , DAC´s, of the dvd player) or either an optical or digital coaxial cable (this would then use the DAC´s of the amp).
You need the optical or digital coaxial cable for 5.1 audio (Dolby/DTS).
For SACD multichannel playback you´ll need to connect three pairs of analogue phono cables from the 5.1 analogue outputs of the dvd player to the 5.1 external inputs of the amp.
I´d just get either an optical or coaxial digital cable (for cd and dolby/dts) and then the three pairs of analogue phono cables.
