Cable question?
Discussion in 'Home Cinema Speakers' started by nickyvicar, May 20, 2003.
  1. nickyvicar
    nickyvicar
    Sep 13, 2002
    277
    +9
    What is the mains cable reccomended as a budget option for surrounds? I have some 24 amp 2.5mm twin & earth but it seems mighty huge for such a task?
    Thanks for any advice,
    Nick
  2. menalaus
    menalaus
    Apr 25, 2003
    338
    sleepy hollow
    +6
    Maybe try 1.5mm twin + earth instead?
  3. bob1
    bob1
    Nov 7, 2002
    4,313
    Sheffield
    +128
    Why not just get some cheap speaker cable from maplins.
  4. sounddog
    sounddog
    Dec 11, 2002
    3,352
    107
    Leicestershire, UK
    +449
    Twin and Earth generally refers to solid core ... flex is what you want ... and you only need 2 core ... and 1.5mm2 will be fine.
    Alternatively B&Q [Edit B&W!! I fink Vikki needs new typing paws, Steph] do 25m of 79strand cable for £10 which is fine for the money (I use it for rear cabling) ... or look at Richer Sounds range.
