Cable question
Discussion in 'Plasma TVs Forum' started by smallangryboy, May 9, 2003.
  1. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    What cable / connector do I need to hook up a standard LCD monitor to a Sky digibox ?
  2. PVR
    PVR
    Oct 23, 2002
    181
    16
    Nr Gatwick
    You will need a JS converter to VGA (RGB2VGA). The standard VGA cable form the LCD screen will fit in there.
    Regards,
    PVR
  3. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
  4. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    the RGB2VGA converter will only work if the LCD monitor can accept a horizontal frequency of 15.625 Khz or Hz or something like that! Most LCDs don't accept this so check it out first....
  5. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    Ah OK - any alternatives ?
  6. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,523
    Kent
    +830
    If the monitor doesn't have any video inputs then a ProV+ or a scaler.
