Cable question from a newbie
Discussion in 'Home Cinema Speakers' started by cslogg, Feb 28, 2003.
  1. cslogg
    cslogg
    Jan 22, 2003
    55
    UK
    Having just bought my first all in one "home cinema" package and connecting up the speakers I noticed the cables looked to be fairly ordinary cheap wiring.Would I really notice much difference if I replaced it with a better quality cabling?It sounds OK to me but then I have been used to a Pro Logic TV with the same sort of cables for the last five years.Bearing in mind that the package I bought is what would probably be called an "entry level"set up.Its a Toshiba by the way.
    cslogg
  2. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    If it's an all in one package then you probably wouldn't notice any difference. I certainly wouldn't want to spend any more than £1/m....
    unless it was a nice colour!
    :D
