Cable Question - anyone?
Discussion in 'AV Receivers & Amplifiers' started by ginga_dj, Jan 24, 2003.
  1. ginga_dj
    ginga_dj
    Jan 12, 2003
    48
    Hello
    I am about to connect my VCR and PS2 to my Amp via composite leads.....(yes, I know, not the best way, but the only option without switching boxes....)
    Anyway. If I purchase a Composite lead (single Phono to Phono) for the video output, is it the same as using a (High Quality) Phono to Phono lead that is designed for Audio......
    Basically is a composite video lead just one half of an Audio lead?
    if it is, I was wondering whether I could split a decent quality Audio lead, and create two compsite video leads?
    I would be grateful to know before I decide to order new leads....
  2. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    It will work, but not as well as a dedicated video/digital lead. The problem is with impedance matching and the much higher frequencys inherent in video.
  3. ginga_dj
    ginga_dj
    Jan 12, 2003
    48
    I have taken your advice and purchased some decent cables from Lektropacks.
