Cable Quality ??
Discussion in 'Cables & Switches' started by Zimfun, Jun 8, 2004.
  1. Zimfun
    Zimfun
    do cables of vastly different prices make that much of a difference when it comes to picture quality ? , for example , does a scart cable that costs £35 produce a VASTLY better picture quality than a scart cable that comes with a cheap DVD player ?
    Also , could someone please explain the difference between RGB and non-RGB scart cables .
    Many thanks
  2. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    There are differences between all types of interconnect and although quality should increase in proportion to price that isn't always the case.
    A scart cable with all pins connected will carry composite, s-video and RGB video signals as well as sound but some scarts - termed RGB scarts - will have some of the wiring missing as they just have sufficient wires to carry RGB picture signals only
