cable q
Discussion in 'Cables & Switches' started by jonnyseale, May 11, 2005.
  1. jonnyseale
    jonnyseale
    :thumbsup: ok i want to put a sky plus box in the attic. and be able to watch it from a projector in the afforementioned room plus bedroom and living room anyone know what is the best way to run a/v to these with no signal loss (not bothered about watching two channels seperately) cheers. :thumbsup:
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    That's almost impossible to answer without knowing the distances involved, and the AV connectors that the devices at the other end will accept.
  3. jonnyseale
    jonnyseale
    sorry have not yet bought stuff everything i get will be high def ready ie: will have (hdcp) hdmi connections at a guess distance a/v will travel would be absoloute max 15m. thanks for the reply by the way :D (oh and probably should mention i think a/v will be output from a scaler)
