theclaretvillai
- Joined
- Sep 10, 2003
- Messages
- 21
- Reaction score
- 0
- Points
- 9
I want to sink my TV wires in the wall under plaster. probably 2 HDMI, 1 usb, 2 CAT. I'd like to be able to change them if something goes wrong. Its a straight run, about 3m. What is the best type of cabling protection/trunking to use? Can you suggest a suitable width and depth?
Also what type would you use if its not a straight run?
Finally (for now) when running speaker cables under plaster do they need trunking or just channel and plaster over.
Thanks in advance, Ken.
