cable or wireless?
Discussion in 'What Speakers Should I Buy?' started by Johnson23, Jan 11, 2012.
  1. Johnson23
    Johnson23
    Jan 4, 2012
    34
    11
    Northants
    Hi, I'm thinking of buying an onkyo tx-nr609 av rec. with a kef kht 3005.se speaker system. Sevenoaks are selling the 3005 system with a wireless sub at the same price as the wired sub system.
    I am a bit cautious about the wireless sub. Will it perform the same as a wired version? Any advice would be appreciated. Thanks.
  2. Faffer
    Faffer
    Apr 29, 2008
    597
    28
    +56
    For me it would be .. Can I put th sub where it needs to be using a cable ?
    If you can do it with a cable I would ... cable is always the best option ..
    Wireless sounds good but only if its a big advantage.
    My question would be ..... Can the wireless be used wired ? if it can then get the wireless and then you have both options.
    Richard
  3. Johnson23
    Johnson23
    Jan 4, 2012
    34
    11
    Northants
    Thanks Richard. Was going to ask if it could be wired. Cheers.
