Cable length
Discussion in 'Home Cinema Speakers' started by jayacee, Jan 23, 2003.
  1. jayacee
    jayacee
    does speaker cable need to be the same length running to all speakers?
    Thanks.
  2. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    If you are a perfectionist, then you should use identical cable lengths for every speaker.
    In reality, I'd make sure front L&R are the same length as each other, and rear L&R are the same length as each other.
    I wouldn't worry too much about front center and rear center (if you have one) matching the appropriate L&R.
  3. jayacee
    jayacee
