Cable interconnect suppliers
Discussion in 'Cables & Switches' started by ivanmurray, Nov 10, 2004.
  1. ivanmurray
    ivanmurray
    Jul 26, 2004
    13
    I am at the final stages of my wireing excercise, and I need to get a ew bits and pieces to clean up the install. I am llloking for the cheapest supplier for ...
    Canare Crimp tool
    Canare Connectors
    QED Wall plates (banna plugs)
    Good quality Banna plugs
    etc.
    Also, I have component video running, and am looking for a neat finish without putting a component face plate in the mix. I was thinking of a one gang face plate, with 3 holes drilled for each component of the video cable. Any better suggestions
    Thanks for the help...
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,392
    Rainham Essex
    +2,451
    Well I don't know about the cheapest, but I'm sure you can get all you want from:
    www.canford.co.uk
    Mark.
