Cable hook-up - need advice!
Discussion in 'LCD & LED LCD TVs Forum' started by Sherman33, Feb 16, 2005.
Tags:
  1. Sherman33
    Sherman33
    SECOND POSTING
    Just purchased Phillips PF 9976.
    What's the best way to hook up my dvd (which has component connections), to the Phillips 9976 which does not have a component connection?
    Recomendations???
    Thanks in advance.
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Did your 9976 come with a Component/VGA/DVI adapter cable? If not, then your TV is probably a v1.3 set which cannot accept component inputs.
    Check this by punching in 123654 and reading the top line. Print it out here if you're not sure what to look for.
    If it's a v2.0, v2.1 or v2.2 then you'll be OK and we'll help you out.
    Jimmy
  3. Sherman33
    Sherman33
    Thanks. I'll check it out as soon as I get home and let you know.
  4. Sherman33
    Sherman33
    Jimmy,
    The line says sw version TX 21 EU-2.2_07771.
    I assume that means version 2.2 (whatever that means).
    Thanks in advance for your assistance.
    Mark
  5. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    I have PM'd you with the connection information. I'll pop it on here if anybody else needs to know.
    Jimmy
  6. ivor61
    ivor61
    May 4, 2005
    41
    olney
    could you put up the connection info as it would be a great help
    thanks
