Cable help please..
Discussion in 'Projectors, Screens & Video Processors' started by KEETY, Jul 23, 2003.
  1. KEETY
    KEETY
    Hello chaps..
    My Panny 100 and HK dvd25 should turn up anyday now.
    My question is, cables, I need a nice long 10-15m component cable to connect these two beauties up.
    After speaking to richers sounds, they suggested that I go to Maplins and buy them from there as it would work out cheaper (i'm not very keen on forking out over £150 on cables).
    What sort of conectors are component? Are they phono or BNC, is there anything else I should know about?
    Thanks for your time.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,152
    +2,970
    You should use good quality crimped RCA phono 75ohm plugs and cables for best results. There are a few suppliers of such cables on these forums. Might be around£150
    Alternatively you can use 3 single lengthsof 75ohm cable with RCA phono plugs. Could be under £50
    Gordon
  3. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    I bought a Vivanco 15m component cable from unbeatable.co.uk for £31.50 delivered.
    Search on the unbeatable site for:
    Vivanco SICRR3315 Cable
    It seems the cheapest around and I'm of the opinion that the other £120 for a £150 cable would be better spent on a new Pal prog dvd player such as the Yamaha S540.
    I can't say if it's any good as I haven't bought a dvd with component out yet. I bought the cable first in case I decide to start chasing the cables into the ceiling and walls.
    Cheers,
    Cal.
