Cable for Kef eggs or Gallo balls
Discussion in 'Home Cinema Speakers' started by Dave777, Jun 9, 2003.
  1. Dave777
    Dave777
    Oct 25, 2002
    480
    Gatwick
    +8
    I'm auditioning the the above speakers to feed off a Denon 3803 sometime soon, but I need to run the cables in the wall now. Can anyone recommend some good value cable for a 6 speaker (i.e. lots!!) in wall run.
    Dave
  2. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    I got good results with B&W 601 surrounds using 79strand cable from B&W ... cost - £10 for 25m. The only problem with it is that the cable sheeth isn;t very well makes for +ve.
    Vikki
    EDIT: Doh Vikki I do believe you mean B&Q Cable!! that's the second time you've made that same typo. Steff
  3. wookie
    wookie
    QED Micro.
  4. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Doh ... yes thats B&Q not B&W!! Very similar stuff to QED original.
    Vikki
  5. NicolasB
    NicolasB
    Oct 3, 2002
    6,070
    Emily's Shop
    +669
    It's a shade pricier, but I think the Maplins 69p per metre stuff is quite good.
  6. Dave777
    Dave777
    Oct 25, 2002
    480
    Gatwick
    +8
    It all seems too cheap:D I'm not used to saying that in home cinema!!
    Thanks folks
    Dave
  7. NicolasB
    NicolasB
    Oct 3, 2002
    6,070
    Emily's Shop
    +669
    "Which?" magazine did some loudspeaker reviews a while back - stereo speakers from about £200 to £500 a pair. As an experiment they tried out three different types of speaker wire. I forget what the middle one was, but the cheap one was the Maplin 69p per metre stuff, and the expensive one was Van den Hul CS122 cable, which is about £9 per metre. Their golden-eared experts reckoned they could hear subtle differences between the three cables, but (crucially) they couldn't decide which of the three they actually preferred.
  8. R32
    R32
    What about Nordost 4 flat? We have used this in the past under carpets and wall paper etc.:)
  9. Dave777
    Dave777
    Oct 25, 2002
    480
    Gatwick
    +8
    As its going to be buried in a cavity wall it doesn't need to be flat and I assume that it costs more for flat???
  10. R32
    R32
    9.99 p/m Almost all of their cables are flat as they believe this to be better that other multi strand designs
  11. rags
    rags
    Apr 13, 2003
    4,087
    London
    +304
    How much do you want to spend and what lengh do you need?
    If for the rear channels and if these are located quite far from your amp I would go for the QED Micro - thin, cheap and half decent. Also imho once you get beyond a 5m-6m run it's pointless buying a more expensive cable (will probably get slapped down for saying that:rolleyes: )
    For the front you could go with QED silver anniversary - I have them in the wall plaster - about £5-6pm
  12. ditton15
    ditton15
    Oct 20, 2002
    535
    16
    edinburgh
    If you buy the Gallo balls from Uncle Eric in the Power Buy, then he supplies the cables for free - or at least he did for me.
    ditton
  13. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    Yep the Gallos are supplied with a long length of solid core cable each, I still use this up front and prefer it to the QED wire I bought for my surround gallos.
  14. Dave777
    Dave777
    Oct 25, 2002
    480
    Gatwick
    +8
    Can you remember how much cable eric supplied?
    Ta
    Dave
  15. James45
    James45
    Sep 21, 2002
    2,844
    59
    it comes boxed with the speakers from Gallo, but you'd have to ask Eric. I'd guess about 3.5 - 4metres, but that could be way off as I cut mine to length ages ago.
