Cable for Genies to Denon AVR-3805
Discussion in 'Home Cinema Speakers' started by Santy, Oct 31, 2004.
  1. Santy
    Santy
    Anyone got any advice for the above please. I have bought every cable going for my custom install apart from the speaker cable.
    Budget reasonable, but sense & sensibility in posts appreciated.
    Thanks all. :smashin:
  2. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    New Zealand was Nottingham
    +86
    QED silver anniversary £5.50 p/m (rrp) and its stunning :thumbsup:
  3. Santy
    Santy
    Thx JD, have heard a few other people rave about this stuff... Only need about 35m so should prove too expensive...
    Anyone else used the QED Ann?
  4. Unlight
    Unlight
    Jan 6, 2003
    1,438
    38
    Belfast
    +9
    Yep - at first I was sceptical about how much of a boost in sound quality I would get over some generic £2 per metre stuff.
    I was absolutley wowed - its crystal clear, top quality speaker cable - absolutely recommended.
    By the way - pop over to ebay, theres usually a guy on there selling it for about £3.40 a metre, should take a bit of a sting off the price :)
  5. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    Another vote for QED SA...only thing I don't like about it is that it's not very flexible.
    Cheers, Lee
  6. chrisp1
    chrisp1
    I also think QED SA is pretty good stuff. Having said that, has anyone else found that if your system tends towards a 'bright' sound, Silver Anniv will work to emphasize this?.
  7. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    +86
    Thing is this stuff is so clear/transparant if you feed it crap you will hear crap. If you are going for a Denon 3805 then you wont be disapointed :thumbsup:
  8. Antpink
    Antpink
    Jan 18, 2004
    468
    43
    Singapore
    +103
    How about running QED SA (have used in past, liked it a lot in an older Stereo set up I had) to the fronts and center, and using the QED micro to the rears? That should save you some pennies.
  9. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,849
    2
    +3,222
    To keep costs down, there would be no harm in using SA on the fronts and Original on the rears- I used to do this and still have the original for my rears.
