Cable extending
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Dan Walton, Feb 3, 2014.
  1. Dan Walton
    Dan Walton
    Apr 20, 2006
    162
    Basingstoke
    +3
    Hi all.
    I'm looking to move my Sky box in our bedroom to another bedroom.
    I was going to order new cable and run it all in new, but I've just seen a few ads in eBay offering extension set ups instead.
    I'm guessing it would be preferable to not have a join in the cables, but will there be any noticeable difference if there was? It would make my life a lot easier...
  2. DJMS
    DJMS
    Jun 6, 2007
    794
    28
    Kent
    +72
    Some will say dont do it but I purchased male/female cable ends from Amazon or Maplin (cant remember which), used these to make a join/extension and sealed in loads of electrical tape. Said join is now in fact buried under an internal doorway encased in concrete.
    I did this to extend cables and wall mount whilst having some building works done inside the house. If I were to do it now I would re run a full length of cable but the join has been there for over 5 years and I have never had an issue.
  3. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    There'll either be no picture at all, or a picture as good as it was before - there's nothing in between.
  4. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,170
    Except reduced signal and increased rain fade margin. :D
    Whatever you decide be cautious buying kits from ebay, a lot feature unbranded cheap tat.
  5. Dan Walton
    Dan Walton
    Apr 20, 2006
    162
    Basingstoke
    +3
    So what should I be looking for/avoiding then? Is there a decent place to buy from?
  6. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    Buy a couple of f-connectors and the length of cable that you need from your local supplier.
  7. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,170
