cable ducts?
Discussion in 'Home Cinema Building DIY' started by garyc, Jul 18, 2005.
  1. garyc
    garyc
    Dec 21, 2002
    866
    Jersey, Channel Islands
    +13
    My plan is run hc cables in 32 or 40mm standard waste pipes as cable ducts behind & throught a plasterboard stud wall but any ideas of how to finish the wall off where the cables come through?
    cheers
    Gary
  2. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    Gary, you can get blanking plates that will finish it off very nicely. If you do a quick search on blanking plates then there are quite a few threads with pictures etc.
  3. KW1816
    KW1816
    Jun 14, 2002
    770
    Surrey
    +14
    I've done as inzaman suggests - used M&K blanking plates to match the sockets I've used. I also found that a pillar drill is almost essential to drill out the face plates neatly.
    For the other cables that I have run to the projector (Component/S-Vid/HDMI etc) I've made a custom plate using MDF and errrr... plumbing fittings :eek: :eek: :D
    It actually looks realy quite good, I've used waste pipe reducers for where the cables exit and it looks like it was made for the job. Go to a decent DIY shed (I used B&Q) that carry a lot of plumbing and cable conduit etc and you'll get some ideas.
    Ta
    Kevin.
  4. garyc
    garyc
    Dec 21, 2002
    866
    +13
    Kevin any chance of some pics?
    Gary
  5. pronto
    pronto
    Feb 9, 2003
    76
    11
    hi gary , heres some pics of my ducting before i plasterboarded and skimmed the walls, http://uk.pg.photos.yahoo.com/ph//my_photos (sorry about the quality)you can d/load the full size if you want,the way i will finish off my cables is by bringing them out of the walls and terminate them with bannana plugs and hide them be hind the speakers like my lounge speakers
  6. MacReady
    MacReady
    Jun 25, 2003
    2,228
    Barnsley, South Yorkshire
    +108
    I got some speaker terminal plates from B&Q and they also sell blanking plates as well as pre drilled ones.
  7. garyc
    garyc
    Dec 21, 2002
    866
    +13
    hi guys,
    pronto your link just takes me to the yahoo front page, not any further?
    cheers
    gary
  8. pronto
    pronto
    Feb 9, 2003
    76
    11
  9. garyc
    garyc
    Dec 21, 2002
    866
    +13
    cheers pronto - pics look good, do you have any of the finished cable duct outlet?
    Gary
  10. Rob_Quads
    Rob_Quads
    Feb 14, 2004
    373
    Chandlers Ford
    +12
  11. pronto
    pronto
    Feb 9, 2003
    76
    11
