Cable connections - help please
Discussion in 'Cables & Switches' started by jon99, Jan 23, 2003.
  1. jon99
    jon99
    Nov 7, 2002
    48
    9
    I have a JVC 32AV25REKS TV with three SCART Skts, A Sky PACE box (2 SCART skts), a JVC HR-J695 VCR (2 SCART skts) and a BUSH DVD player (1 SCART skt).
    Currently I have 3 Fully wired SCART leads connecting as follows:
    VCR to Skybox
    Skybox to TV (RGB SCART skt 1)
    DVD to TV (SCART skt 2)
    I have a spare SCART lead but it isn't fully wired.
    Using the above how can I get the best set-up?
    Thanks for your help.
    Jon:)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Idealy you want DVD>RGB have you 2 or 1 RGB scarts, If one then you will probably need a scart splitter. How often do you Record sky?
    DVD>SKY>RGB
    VCR>SCART
    Or If your VCR does RGB Pass through, I think most willl only do composite.
    DVD>VCR>SKY>RGB
  3. jon99
    jon99
    Nov 7, 2002
    48
    9
    Thanks Horny Dragon
    I'll give it try.
    Currently I have set it to:
    EXT 2 >> Video 1
    Video 2 >> Sky 2
    SKY 1 >> EXT 1
    DVD >> EXT 3
    It all works except auto-record from SKY as I am stuck over what the set up means by SAT PROG value 1 - 999?
    The TV SCARTS are described as follows:
    Ext1 = Video input, Audio L/R inputs and RGB inputs
    TV broadcast outputs (Video and Audio L/R)
    Ext2 = Video input, S-Video (Y/C) input and Audio L/R inputs
    Video and Audio L/R outputs
    TV LINK functions
    Ext3 = Video input, S-Video (Y/C) input and Audio L/R inputs
    Ext4= RCA Connectorts x 2
    Variable audio L/R outputs
    Variable out 0-1 Vrms, low impedance
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Have you got the DVD set to S-vid?
    As regards the sat recording try posting in the sat forum listing the problem and the kit you are using. I don't use sat so its a bit hard for me to answer
  5. jon99
    jon99
    Nov 7, 2002
    48
    9
    Hi thanks for all the good advice.
    I took the VCR back to the seller and replaced it with a Panasonic S-VHS.
    Cabled up as before with a new SCART cable for the DVD and everything now wortks OK, including having the system record automatically when the sky box automatically turns on and switches channels.
    Quality of the VCR is much better.
    Thanks again.
  6. Kevo
    Kevo
    Aug 23, 2001
    5,362
    Manchester
    +146
    Does your Sky STB output S-Video to your VCR?
    If not, then you won't be getting the best recordings from your STB.
    I purchased and 'RGB to S-video' converter and it made ALL the difference. MUCH better quality recordings from my Pace cable stb.
    BTW, although an SVHS VCR is obviously a better choice over VHS, you may have complicated your wiring set up no end.
    That is....IF your STB doesn't have S-Video out and you DO want to record the way I described above (which I highly recommend and am sure others will agree).
    I had to buy an amplified SCART splitter to split the outcoming RGB from my STB. One then goes to the TV and the other goes to the converter which then goes to my SVHS VCR!
    I'm now in a similar dilemna where I want to purchase a freeview stb/adaptor, but am holding off for the simple reason that NONE offer RGB AND S-Video out. I can't go back to recording to composite on SVHS and am unwilling to buy ANOTHER converter and splitter!
